Did you know you have the Assay Module SDK?
Posted: October 21, 2021
Are you using AVEVA Unified Supply Chain: Assay to it’s full capabilities?
Integration is at Your Fingertips, and You Probably Don’t Even Know It
We have noticed that many customers do not know that they have Assay SDK available to them as part of their license. That is our fault. We need to do a better job at letting you know that you have access to this as part of your Assay license. Now that you are aware, how will you use the Assay SDK in your value chain?
Check out this video to learn more about AVEVA Unified Supply Chain: Assay SDK
Adding to Your Unified Supply Chain
Software tools are rarely used in isolation. Each software tool should interface with existing business process, allowing users to bring input in from diverse systems, and transfer results and decisions out across the enterprise. Even if you use AVEVA Unified Supply Chain to unify your Oil and Gas supply chain, the rest of your value chain likely has many legacy point solutions. These legacy point solutions often require individual integration, which is difficult to maintain and often requires different skills to build and enhance as end user requirements change.
Bottom Line: If it is not unified, it needs to be integrated!
Software tools are rarely used in isolation. Legacy point solutions must interface with existing business process, allowing users to bring input in from diverse systems, and transfer results and decisions out across the enterprise. Legacy point solutions often require individual integration points, which are difficult to maintain and extend, and each of which requires different skills to build and enhance as end user requirements change. AVEVA Unified Supply Chain: SDK integrates your supply chain software with your legacy point solutions. SDK stands for Software Developer Kit, but it isn’t as complicated as that sounds.
Integration, Simplified
AVEVA Unified Supply Chain SDK solves legacy integration problems with a modern application programming interface, allowing direct access to the unified knowledge shared by AVEVA Unified Supply Chain across the enterprise. The benefits of AVEVA Unified Supply Chain SDK include:
  • Accessible via code or via Microsoft Excel. This allows people to use whichever program they are most familiar with to integrate legacy point solutions.
  • Access via .NET or COM gives added flexibility because different legacy point solutions will have different integration requirements
  • Easy to use API for consistent coding reduces the barrier of entry
  • Data changes saved in AVEVA Unified Supply Chain ensuring accountability, traceability, and consistency
To find out more, I’d have, watch the video or contact support at [email protected]
Related Blog Posts
