Insight | March 2020
Simplifying operational complexity
Posted: April 1, 2020
Welcome to another issue of our AVEVA Operations Control blog where we showcase the latest updates, features, tips and tricks - all designed to help you get the most out of your system.
For new readers, AVEVA Insight is a cloud-based industrial solution for operations. It provides the tools you need for operational continuity, effectiveness and improvement. Not only does it unlock trapped data, but it makes industrial analytics available to everyone so that information silos are effectively overcome. Insight enables users of all levels and experience to monitor and visualize real-time data to improve efficiency and optimize performance.
What's new in AVEVA Insight?
  • Calculated statistics for events
  • Clutter-free search
  • Managing production shifts
  • Enhancements to OEE and production capabilities
  • Custom actions for alerts
  • Subscription banners
Since the beginning, AVEVA Insight could show summary statistics for common intervals e.g. an hour. Now, we’ve added option to have the same statistics calculated based on an event, such as a batch ID, product code, or digital value. Here, each group of columns represents a batch. Click on a column to get the exact period with the option to drill through to a Line Chart just for that batch.
AVEVA Insight now allows calculated statistics for events
This makes it much easier to analyze the data relevant to you, and make better, faster decisions.
Clutter-free search
Search is a super-simple way to find data of interest, but sometimes you end up with extra results that can clutter your content. You told us that you’d like a way to remove those extra tags from your result set so now, you can remove tags just as easily as you can add them. Simply open the tag dictionary and select the tags you want removed, and hit remove. That's it, clutter-free content is all yours.
Clutter-free search of your industrial tags is easy with AVEVA Insight
Managing Production shift
To make it even easier to manage your production shifts we have introduced new capabilities around asset time zones, and shift patterns.
Each asset now has an associated time zone. Like other metadata on the Asset Page, the time zone can be configured by clicking on the Asset Info card and selecting the time zone from list of options available in the sidesheet. This can be configured by any user with Admin privileges.
Configuring asset time zones in AVEVA Insight
The time zone supports the ability to define shift patterns for production. A shift pattern is simply a collection of shifts, and you can create multiple shift patterns to suit your organization's needs. For example you might have a different shift pattern for different times of the year, or days of the week.
Each shift pattern has a name, an effective date for when it becomes active in the system, and a list of locations to which it will apply. This means that different locations may be setup with different shift patterns to match local operating procedures. Within the shift pattern, you can define multiple shifts. Each shift has a start time (which is based on the local time of the asset) and a day of the week to which it applies. Each shift continues until it is replaced by the next defined shift, so if you have periods where this is no shift, then you would define those time periods as well. Here we can see how shift patterns would be configured within the Administration tool.
With AVEVA Insight it is easy to define Shift Patterns to suit your Operational procedures
Once you have defined the shift patterns and applied them to the right assets, you can then access this information in various places throughout Insight. On the Utilization and production events tabs for an asset, you can now filter the visible information by Current Shift (in addition to the time or production run options previously available). KPIs and asset information will now refer to the current shift. On the production events tab, some information still relates to the active run, such as total quantities produced and target values, as this is the most important information in that view.
Defined Shift Patterns can be used to navigate content
The OEE analysis view also now supports grouping events by shift, providing summary data such as average availability, OEE, performance and quality by shift.
On the OEE pages, you can now easily see which utilization events have had comments added to them, making it easier to capture information at a glance.  You can also retrieve those comments directly from the Pareto charts.  In this example, you can see that the top downtime reason is an infeed jam, and users have added 3 comments to help the user understand what has happened during these events.  Understanding this information helps users better understand issues and collaborate to improve performance of the system overall.
Access comments directly from your Pareto charts
When we switch to the production events tab, you can see that for a very long production run, the production window now displays for the last 7 days.  This ensures that you continue to get a quick response time on the production events tab, even when there is a lot of data to process.  The grey highlighted text shows the production window represented on the page.
The production window in AVEVA Insight now displays the last 7 days
The Estimated Completion Date and Production Progress information is not available since production counts before the start of the window 7 days ago are not known and the Actual Production Rate, Pareto Bar charts, and OEE KPIs are all calculated for the 7 days shown on the page.  If you do want to see older data associated with this production run, you can still go and see this through the OEE analysis pages.
As part of our ongoing investment in condition management, we’ve continued to improve the alerts capabilities in Insight. Now we are simplifying and extending custom actions and adding support for consequence of failure configuration as part of the alert definition.
Custom actions allow you to setup Azure logic apps to trigger based on an alert condition being met. A common use case might allow alerts to trigger a work order in an external asset management solution such as Avantis or SAP.
Define the custom action by providing the name, description, Logic App URL and any optional parameters to be passed to the logic app when the alert is triggered.  You’ll notice that the parameters in this example have been separated using the pipe symbol.  This tells Insight to show them as separate configuration fields in the alert definition, making it simpler for users to understand and configure the action in their alerts. Once you get to the actions page of the alert, select the custom action, update the information and fill in the appropriate parameters needed for the alert to be sent. Now AVEVA Insight will trigger the necessary action whenever the alert parameters are met, and you will be kept up-to-date with system behavior.
Create custom actions for your alerts using AVEVA Insight and Azure logic apps
We’ve also added consequence of failure information that can be configured for an alert.  Simply enable this in the wizard and configure the notifications that you want to send to the user – if this alert has implications related to safety, environmental impacts or production performance.  The user will then be notified of this when they receive the alert, giving them additional context with which to respond to the alert that they receive.
Finally, we heard your feedback for more information to remind you when your subscription was expiring, so we’ve added banners to remind you when your renewal date is close.  Within 30 days of expiration, solution administrators will be notified of the number of remaining days so they can action the renewal.  If the solution then expires, all users will be notified through the banner that the solution is overdue for renewal.
And that's it for this update. I hope you enjoy these changes and if you have ideas around these features, or any others, please send them through to [email protected]
Discover Insight for yourself!
We offer a public demo and a free, 45-day trial of AVEVA Insight so you can see how you can drive operational continuity in your business quickly and easily. No coding, or expensive projects required. Try it free at https://insight.connect.aveva.com
See What AVEVA Insight Can Do for You
Use the button below to find an AVEVA partner who can free you from the day-to-day worries of managing large, complex data application.
Related blog posts
